Datasheet LT1013IS8 - Linear Technology Даташит ИС, операционный усилитель, 800 кГц, 0.4 В/мкс, SOIC-8 — Даташит
Наименование модели: LT1013IS8
![]() 43 предложений от 24 поставщиков Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1013IS8#PBF Operational Amplifier, Dual, 2 Amplifier, 0.4V/µs, ± 2V to ± 18V, SOIC, 8Pins | |||
LT1013IS8#PBF Analog Devices | 267 ₽ | ||
LT1013IS8#PBF Analog Devices | от 336 ₽ | ||
LT1013IS8#TR | по запросу | ||
LT1013IS8TR | по запросу |
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 800 кГц, 0.4 В/мкс, SOIC-8
FEATURES
LT1013/LT1014 Quad Precision Op Amp (LT1014) Dual Precision Op Amp (LT1013) DESCRIPTIO
The LT ®1014 is the first precision quad operational amplifier which directly upgrades designs in the industry standard 14-pin DIP LM324/LM348/OP-11/4156 pin configuration.
It is no longer necessary to compromise specifications, while saving board space and cost, as compared to single operational amplifiers. The LT1014's low offset voltage of 50V, drift of 0.3V/°C, offset current of 0.15nA, gain of 8 million, common mode rejection of 117dB and power supply rejection of 120dB qualify it as four truly precision operational amplifiers. Particularly important is the low offset voltage, since no offset null terminals are provided in the quad configuration. Although supply current is only 350A per amplifier, a new output stage design sources and sinks in excess of 20mA of load current, while retaining high voltage gain. Similarly, the LT1013 is the first precision dual op amp in the 8-pin indust
- Тип ОУ: Precision
- Количество усилителей: 2
- Полоса частот: 800 кГц
- Slew Rate: 0.4 В/мкс
- Диапазон напряжения питания: ± 2 В ... ± 18 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
