Datasheet LT1078IS8 - Linear Technology Даташит ИС, операционный усилитель, 200 кГц, 0.07 В/мкс, SOIC-8 — Даташит
Наименование модели: LT1078IS8
![]() 38 предложений от 21 поставщиков Micropower, Dual and Quad, Single Supply, Precision Op Amps | IC OPAMP GP 2 CIRCUIT 8SO | |||
LT1078IS8#PBF Analog Devices | 195 ₽ | ||
LT1078IS8#TRPBF Linear Technology | 370 ₽ | ||
LT1078IS8#PBF Linear Technology | от 474 ₽ | ||
LT1078IS8#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 200 кГц, 0.07 В/мкс, SOIC-8
FEATURES
s s s s s s s s s s s
LT1078/LT1079 Micropower, Dual and Quad, Single Supply, Precision Op Amps DESCRIPTIO
The LT ® 1078 is a micropower dual op amp in 8-pin packages including the small outline surface mount package.
The LT1079 is a micropower quad op amp offered in the standard 14-pin packages. Both devices are optimized for single supply operation at 5V. ±15V specifications are also provided. Micropower performance of competing devices is achieved at the expense of seriously degrading precision, noise, speed and output drive specifications. The design effort of the LT1078/LT1079 was concentrated on reducing supply current without sacrificing other parameters. The offset voltage achieved is the lowest on any dual or quad nonchopper stabilized op amp--micropower or otherwise. Offset current, voltage and current noise, slew rate and gain bandwidth product are all two to ten times better than on previous micropower op amps. The 1/f corner of the voltage noise spectrum is at 0.
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 200 кГц
- Slew Rate: 0.07 В/мкс
- Диапазон напряжения питания: 2.3 В ... 12 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
