Datasheet LT1367CS - Linear Technology Даташит ИС, операционный усилитель, 400 кГц, 0.13 В/мкс, SOIC-14 — Даташит
Linear Technology LT1367CS
Наименование модели: LT1367CS
42 предложений от 25 поставщиков
LT1367CS#PBF
от 1 690 ₽
Элитан
LT1367CS
1 712 ₽
LT1367CS
SUV System
LT1367CS
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 400 кГц, 0.13 В/мкс, SOIC-14
data sheetСкачать Data Sheet
LT1366/LT1367 LT1368/LT1369 Dual and Quad Precision Rail-to-Rail Input and Output Op Amps
FEATURES
s s s s s s s s s s s s
DESCRIPTION
The LT ®1366/LT1367/LT1368/LT1369 are dual and quad bipolar op amps which combine rail-to-rail input and output operation with precision specifications.
These op amps maintain their characteristics over a supply range of 1.8V to 36V. Operation is specified for 3V, 5V and ±15V supplies. Input offset voltage is typically 150µV, with an open-loop gain AVOL of 1 million while driving a 10k load. Common mode rejection is typically 90dB over the full railto-rail input range, and supply rejection is 110dB. The LT1366/LT1367 have conventional compensation which assures stability for capacitive loads of 1000pF or less. The LT1368/LT1369 have compensation that requires a 0.1µF output capacitor, which improves the amplifier's supply rejection and reduces output impedance at high frequencies. The output capacitor's filtering action reduces high frequency noise, w
  • Тип ОУ: Precision
  • Количество усилителей: 4
  • Полоса частот: 400 кГц
  • Slew Rate: 0.13 В/мкс
  • Диапазон напряжения питания: 1.8 В ... ± 15 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 14
На английском языке: Datasheet LT1367CS - Linear Technology IC, OP-AMP, 400 kHz, 0.13 V/µs, SOIC-14
