Datasheet LTC6246HS6 - Linear Technology Даташит ИС, операционный усилитель, 180 МГц, 90 В/мкс, 500 мкВ, 6-SOT-23 — Даташит
Наименование модели: LTC6246HS6
![]() 31 предложений от 19 поставщиков Микросхема Операционный усилитель, LINEAR TECHNOLOGY LTC6246HS6#TRMPBF Operational Amplifier, Single, 1 Amplifier, 180MHz, 90V/µs, 2.5V to 5.25V, SOT-23, 6Pins | |||
LTC6246HS6#TRMPBF Linear Technology | 333 ₽ | ||
LTC6246HS6#TRMPBF Analog Devices | 564 ₽ | ||
LTC6246HS6#TRMPBF Linear Technology | по запросу | ||
LTC6246HS6#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 180 МГц, 90 В/мкс, 500 мкВ, 6-SOT-23
FeaTures
n n n n n n n n n n n n n n n n n n n
LTC6246/LTC6247/LTC6248 180MHz, 1mA Power Efficient Rail-to-Rail I/O Op Amps DescripTion
The LTC®6246/LTC6247/LTC6248 are single/dual/quad low power, high speed unity gain stable rail-to-rail input/output operational amplifiers.
On only 1mA of supply current they feature an impressive 180MHz gain-bandwidth product, 90V/µs slew rate and a low 4.2nV/Hz of input-referred noise. The combination of high bandwidth, high slew rate, low power consumption and low broadband noise makes these amplifiers unique among rail-to-rail input/output op amps with similar supply currents. They are ideal for lower supply voltage high speed signal conditioning systems. The LTC6246 family maintains high efficiency performance from supply voltage levels of 2.5V to 5.25V and is fully specified at supplies of 2.7V and 5.0V. For applications that require power-down, the LTC6246 and the LTC6247 in MS10 offer a shutdown pin which disables the amplifier and reduces cur
- Тип ОУ: Low Power
- Количество усилителей: 1
- Полоса частот: 180 МГц
- Скорость нарастания: 90 В/мкс
- Диапазон напряжения питания: 2.5 В ... 5.25 В
- Тип корпуса: SOT-23
- Количество выводов: 6
