Datasheet LTC6253CMS8 - Linear Technology Даташит ИС, операционный усилитель, 720 МГц, 280 В/мкс, 350 мкВ, MSOP-8 — Даташит
Наименование модели: LTC6253CMS8
![]() 32 предложений от 17 поставщиков Микросхема Буферный усилитель, LINEAR TECHNOLOGY LTC6253CMS8#PBF Operational Amplifier, Dual, 2 Amplifier, 720MHz, 280V/µs, 2.5V to 5.25V, MSOP, 10Pins | |||
LTC6253CMS8#TRPBF Linear Technology | 246 ₽ | ||
LTC6253CMS8#TRPBF | 263 ₽ | ||
LTC6253CMS8#PBF Analog Devices | от 1 037 ₽ | ||
LTC6253CMS8#PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 720 МГц, 280 В/мкс, 350 мкВ, MSOP-8
FEATURES
n n n n n n n n n n n n n n n n n n
LTC6252/LTC6253/LTC6254 720MHz, 3.5mA Power Efficient Rail-to-Rail I/O Op Amps DESCRIPTION
The LTC®6252/LTC6253/LTC6254 are single/dual/quad low power, high speed unity gain stable rail-to-rail input/output operational amplifiers.
On only 3.5mA of supply current they feature a 720MHz gain-bandwidth product, 280V/s slew rate and a low 2.75nV/Hz of input-referred noise. The combination of high bandwidth, high slew rate, low power consumption and low broadband noise makes the LTC6252 family unique among rail-to-rail input/output op amps with similar supply currents. They are ideal for lower supply voltage high speed signal conditioning systems. The LTC6252 family maintains high efficiency performance from supply voltage levels of 2.5V to 5.25V and is fully specified at supplies of 2.7V and 5.0V. For applications that require power-down, the LTC6252 and the LTC6253 in MS10 offer a shutdown pin which disables the amplifier and reduces current co
- Тип ОУ: Unity Gain Stable
- Количество усилителей: 2
- Полоса частот: 720 МГц
- Скорость нарастания: 280 В/мкс
- Диапазон напряжения питания: 2.5 В ... 5.25 В
- Тип корпуса: MSOP
- Количество выводов: 10
