Datasheet EL2045CN - Intersil Даташит ИС, операционный усилитель, SINGLE, 8PDIP — Даташит
Наименование модели: EL2045CN
![]() 15 предложений от 15 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
EL2045CN Elantec | 103 ₽ | ||
EL2045CN Elantec | 317 ₽ | ||
EL2045CN Intersil | 444 ₽ | ||
EL2045CN Intersil | 2 256 ₽ |
Производитель: Intersil
Описание: ИС, операционный усилитель, SINGLE, 8PDIP
EL2045
Data Sheet February 11, 2005 FN7030.1
Low-Power 100MHz Gain-of-2 Stable Operational Amplifier
The EL2045 is a high speed, low power, low cost monolithic operational amplifier built on Elantec's proprietary complementary bipolar process.
The EL2045 is gain-of-2 stable and features a 275V/µs slew rate and 100MHz gainbandwidth at gain-of-2 while requiring only 5.2mA of supply current. The power supply operating range of the EL2045 is from ±18V down to as little as ±2V. For single-supply operation, the EL2045 operates from 36V down to as little as 2.5V. The excellent power supply operating range of the EL2045 makes it an obvious choice for applications on a single +5V or +3V supply. The EL2045 also features an extremely wide output voltage swing of ±13.6V with VS = ±15V and RL = 1k. At ±5V, output voltage swing is a wide ±3.8V with RL = 500 and ±3.2V with RL = 150. Furthermore, for single-supply operation at +5V, output voltage swing is an excellent 0.3V to 3.8V with RL = 500. A
- Тип ОУ: Low Power
- Количество усилителей: 1
- Полоса частот: 100 МГц
- Скорость нарастания: 275 В/мкс
- Диапазон напряжения питания: ± 2 В ... ± 18 В
- Тип корпуса: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Добротность: 100 МГц
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Multicomp - 2227MC-08-03-18-F1
- Multicomp - 2227MC-08-03-F1
