Datasheet HA7-2645-5 - Intersil Даташит ИС, операционный усилитель, 4 МГц, 5 В/мкс, DIP-8 — Даташит
Intersil HA7-2645-5
Наименование модели: HA7-2645-5
General Purpose Amplifier 1 Circuit 8-CERDIP
HA7-2645-5
Renesas
МосЧип
HA72645-5
LifeElectronics
HA7-2645--5
HA7-2645-5
Renesas
Производитель: Intersil
Описание: ИС, операционный усилитель, 4 МГц, 5 В/мкс, DIP-8
data sheetСкачать Data Sheet
HA-2640, HA-2645
Data Sheet January 3, 2006 FN2904.5
4MHz, High Supply Voltage Operational Amplifiers
HA-2640 and HA-2645 are monolithic operational amplifiers which are designed to deliver unprecedented dynamic specifications for a high voltage internally compensated device.
These dielectrically isolated devices offer very low values for offset voltage and offset current coupled with large output voltage swing and common mode input voltage. For maximum reliability, these amplifiers offer unconditional output overload protection through current limiting and a chip temperature sensing circuit. This sensing device turns the amplifier "off", when the chip reaches a certain temperature level. These amplifiers deliver ±35V common mode input voltage range, ±35V output voltage swing, and up to ±40V supply range for use in such designs as regulators, power supplies, and industrial control systems. 4MHz gain bandwidth and 5V/µs slew rate make these devices excellent components for high perf
  • Тип ОУ: High Voltage
  • Количество усилителей: 1
  • Полоса частот: 4 МГц
  • Скорость нарастания: 5 В/мкс
  • Диапазон напряжения питания: ± 10 В ... ± 40 В
  • Тип корпуса: DIP
  • Количество выводов: 8
HA726455, HA7 2645 5
На английском языке: Datasheet HA7-2645-5 - Intersil IC, OP-AMP, 4 MHz, 5 V/µs, DIP-8
