Datasheet AD606JNZ - Analog Devices Даташит ИС, усилитель, LOG 80 дБ, PDIP16, 606 — Даташит
Наименование модели: AD606JNZ
Производитель: Analog Devices
Описание: ИС, усилитель, LOG 80 дБ, PDIP16, 606
a
50 MHz, 80 dB Demodulating Logarithmic Amplifier with Limiter Output AD606
a loadable output voltage of +0.1 V dc to +4 V dc.
The logarithmic scaling is such that the output is +0.5 V for a sinusoidal input of 75 dBm and +3.5 V at an input of +5 dBm; over this range the logarithmic linearity is typically within ± 0.4 dB. All scaling parameters are proportional to the supply voltage. The AD606 can operate above and below these limits, with reduced linearity, to provide as much as 90 dB of conversion range. A second low-pass filter automatically nulls the input offset of the first stage down to the submicrovolt level. Adding external capacitors to both filters allows operation at input frequencies as low as a few hertz. The AD606's limiter output provides a hard-limited signal output as a differential current of ± 1.2 mA from open-collector outputs. In a typical application, both of these outputs are loaded by 200 resistors to provide a voltage gain of more than 90 dB from the input
- Количество усилителей: 1
- Время отклика: 5 мкс
- Диапазон напряжения питания: 4.5 В ... 5.5 В
- Тип корпуса: DIP
- Количество выводов: 16
- SVHC: No SVHC (18-Jun-2010)
- Полоса частот: 50 МГц
- Семейство: 606
- Рабочий диапазон температрур: 0°C ... +70°C
- Напряжение питания (+) номинальное: 5 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD E 15 SA
- STANNOL - 631954
