Datasheet LF442ACN/NOPB - National Semiconductor Даташит Операционный усилитель, сдвоенный, LO PWR JFET, 8-DIP — Даташит
Наименование модели: LF442ACN/NOPB
![]() 11 предложений от 11 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LF442ACN/NOPB Operational Amplifier, Dual, 2 Amplifier, 1MHz, 1V/µs, 6V to 44V, DIP, 8Pins | |||
LF442ACN/NOPB Texas Instruments | 81 ₽ | ||
LF442ACN/NOPB Rochester Electronics | 207 ₽ | ||
LF442ACN/NOPB Texas Instruments | по запросу | ||
LF442ACN/NOPB National Semiconductor | по запросу |
Описание: Операционный усилитель, сдвоенный, LO PWR JFET, 8-DIP
LF442 Dual Low Power JFET Input Operational Amplifier
August 2000
General Description
The LF442 dual low power operational amplifiers provide many of the same AC characteristics as the industry standard LM1458 while greatly improving the DC characteristics of the LM1458.
The amplifiers have the same bandwidth, slew rate, and gain (10 k load) as the LM1458 and only draw one tenth the supply current of the LM1458. In addition the well matched high voltage JFET input devices of the LF442 reduce the input bias and offset currents by a factor of 10,000 over the LM1458. A combination of careful layout design and internal trimming guarantees very low input offset voltage and voltage drift. The LF442 also has a very low equivalent input noise voltage for a low power amplifier. The LF442 is pin compatible with the LM1458 allowing an immediate 10 times reduction in power drain in many applications. The LF442 should be used where low power d
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 1 МГц
- Скорость нарастания: 1 В/мкс
- Диапазон напряжения питания: 6 В ... 44 В
- Тип корпуса: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 442
- Добротность: 1 МГц
- Рабочий диапазон температрур: -65°C ... +150°C
- Способ монтажа: Through Hole
