Datasheet LM10CN - National Semiconductor Даташит ИС, OP AMP/VOLT REF, DIP8 — Даташит
Наименование модели: LM10CN
![]() 44 предложений от 23 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM10CN/NOPB Operational Amplifier, Dual, 2 Amplifier, 90kHz, 0.2V/µs, 1.1V to 45V, DIP, 8Pins | |||
LM10CN/NOPB Texas Instruments | от 235 ₽ | ||
LM10CN/NOPB Texas Instruments | от 363 ₽ | ||
LM10CN/NOPB Texas Instruments | 386 ₽ | ||
LM10CN* Texas Instruments | по запросу |
Описание: ИС, OP AMP/VOLT REF, DIP8
LM10 Operational Amplifier and Voltage Reference
August 2000
General Description
The LM10 series are monolithic linear ICs consisting of a precision reference, an adjustable reference buffer and an independent, high quality op amp.
The unit can operate from a total supply voltage as low as 1.1V or as high as 40V, drawing only 270µA. A complementary output stage swings within 15 mV of the supply terminals or will deliver ± 20 mA output current with ± 0.4V saturation. Reference output can be as low as 200 mV. The circuit is recommended for portable equipment and is completely specified for operation from a single power cell. In contrast, high output-drive capability, both voltage and current, along with thermal overload protection, suggest it in demanding general-purpose applications. The device is capable of operating in a floating mode, independent of fixed supplies. It can function as a remote comparator, signal conditioner, SCR contr
- Тип ОУ: General Purpose
- Количество усилителей: 1
- Полоса частот: 0.09 МГц
- Скорость нарастания: 0.2 В/мкс
- Диапазон напряжения питания: 1.1 В ... 45 В
- Тип корпуса: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип усилителя: Voltage Reference
- Семейство: 10
- Quiescent Current Typ: 270 мкА
- Маркировка: LM10CN
- Добротность: 0.4 МГц
- IC Generic Number: 10
- Рабочий диапазон температрур: Commercial
- Напряжение смещения входа максимальное: 5 мВ
- Количество логических функций: 10
- Особенности ОУ: voltage reference
- Напряжение питания (+) номинальное: 40 В
- Напряжение питания (-) номинальное: 1.1 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK SMD A 8 SA
- Fischer Elektronik - WLK 5
- Multicomp - 2227MC-08-03-18-F1
