Datasheet LM10CWM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, одиночный, SMD — Даташит
Наименование модели: LM10CWM/NOPB
![]() 46 предложений от 16 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM10CWM/NOPB Operational Amplifier, Single, 1 Amplifier, 90kHz, 0.2V/µs, 1.1V to 45V, SOIC, 14Pins | |||
LM10CWM/NOPB Texas Instruments | 85 ₽ | ||
LM10CWM/NOPB Texas Instruments | от 144 ₽ | ||
LM10CWM/NOPB Texas Instruments | от 193 ₽ | ||
LM10CWM/NOPB Texas Instruments | 290 ₽ |
Описание: ИС, операционный усилитель, одиночный, SMD
LM10 Operational Amplifier and Voltage Reference
August 2000
General Description
The LM10 series are monolithic linear ICs consisting of a precision reference, an adjustable reference buffer and an independent, high quality op amp.
The unit can operate from a total supply voltage as low as 1.1V or as high as 40V, drawing only 270µA. A complementary output stage swings within 15 mV of the supply terminals or will deliver ± 20 mA output current with ± 0.4V saturation. Reference output can be as low as 200 mV. The circuit is recommended for portable equipment and is completely specified for operation from a single power cell. In contrast, high output-drive capability, both voltage and current, along with thermal overload protection, suggest it in demanding general-purpose applications. The device is capable of operating in a floating mode, independent of fixed supplies. It can function as a remote comparator, signal conditioner, SCR contr
- Тип ОУ: General Purpose
- Количество усилителей: 1
- Скорость нарастания: 0.2 В/мкс
- Диапазон напряжения питания: 1.1 В ... 45 В
- Тип корпуса: SOIC
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Добротность: 0.4 МГц
- Напряжение смещения входа максимальное: 4 мВ
- Рабочий диапазон температрур: 0°C ... +70°C
- Способ монтажа: SMD
Дополнительные аксессуары:
- Roth Elektronik - RE932-03
- STANNOL - 574601
