Datasheet LM358N/NOPB - National Semiconductor Даташит ИС, операционный усилитель, сдвоенный — Даташит
National Semiconductor LM358N/NOPB
Наименование модели: LM358N/NOPB
48 предложений от 21 поставщиков
LM358N/NOPB
от 8.90 ₽
LM358N/NOPB
727GS
LM358N/NOPB
LM358N/NOPB
Описание: ИС, операционный усилитель, сдвоенный
data sheetСкачать Data Sheet
LM158/LM258/LM358/LM2904 Low Power Dual Operational Amplifiers
October 2005
General Description
The LM158 series consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM158 series can be directly operated off of the standard +5V power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring the additional ± 15V power supplies. The LM358 and LM2904 are available in a chip s
Данные для моделированияДанные для моделирования
  • Тип ОУ: Low Power
  • Количество усилителей: 2
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.1 В/мкс
  • Диапазон напряжения питания: 3 В ... 32 В
  • Тип корпуса: DIP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Добротность: 1 МГц
  • Рабочий диапазон температрур: 0°C ... +70°C
Дополнительные аксессуары:
  • Fischer Elektronik - ICK SMD A 8 SA
  • Fischer Elektronik - WLK 5
  • STMicroelectronics - LM358N
На английском языке: Datasheet LM358N/NOPB - National Semiconductor IC, OP AMP, DUAL
