Datasheet LM611IM/NOPB - National Semiconductor Даташит ИС, операционный усилитель ADJ REF 14-SO — Даташит
National Semiconductor LM611IM/NOPB
Наименование модели: LM611IM/NOPB
Микросхема Операционный усилитель, Operational Amplifier, Dual, 2 Amplifier, 800kHz, 0.7V/µs, 4V to 36V, SOIC, 14Pins
727GS
LM611IM/NOPB
55 ₽
LM611IM/NOPB
62 ₽
LM611IM/NOPB
LM611IM/NOPB
Описание: ИС, операционный усилитель ADJ REF 14-SO
data sheetСкачать Data Sheet
LM611 Operational Amplifier and Adjustable Reference
August 2000
General Description
The LM611 consists of a single-supply op-amp and a programmable voltage reference in one space saving 8-pin package.
The op-amp out-performs most single-supply opamps by providing higher speed and bandwidth along with low supply current. This device was specifically designed to lower cost and board space requirements in transducer, test, measurement and data acquisition systems. Combining a stable voltage reference with a wide output swing op-amp makes the LM611 ideal for single supply transducers, signal conditioning and bridge driving where large common-mode signals are common. The voltage reference consists of a reliable band-gap design that maintains low dynamic output impedance (1 typical), excellent initial tolerance (0.6%), and the ability to be programmed from 1.2V to 6.3V via two external resistors. The voltage reference is very stable eve
  • Тип ОУ: High Speed
  • Количество усилителей: 1
  • Полоса частот: 800 кГц
  • Скорость нарастания: 0.7 В/мкс
  • Диапазон напряжения питания: 4 В ... 36 В
  • Тип корпуса: SOIC
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Семейство: 611
  • Добротность: 0.8 МГц
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Способ монтажа: SMD
На английском языке: Datasheet LM611IM/NOPB - National Semiconductor IC, OP AMP ADJ REF 14-SO
