Datasheet LM7372IMA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, сдвоенный, HI SPD, 16-SO — Даташит
Наименование модели: LM7372IMA/NOPB
20 предложений от 20 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM7372IMA/NOPB Operational Amplifier, Dual, 2 Amplifier, 120MHz, 3000V/µs, 9V to 36V, SOIC, 16Pins | |||
| LM7372IMA/NOPB Texas Instruments | 247 ₽ | ||
| LM7372IMA/NOPB Texas Instruments | 318 ₽ | ||
| LM7372IMA/NOPB Texas Instruments | 1 080 ₽ | ||
| LM7372IMA/NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, сдвоенный, HI SPD, 16-SO
LM7372 High Speed, High Output Current, Dual Operational Amplifier
June 24, 2008
General Description
The LM7372 is a high speed dual voltage feedback amplifier that has the slewing characteristic of current feedback amplifiers; yet it can be used in all traditional voltage feedback amplifier configurations.
The LM7372 is stable for gains as low as +2 or -1. It provides a very high slew rate at 3000V/µs and a wide gain bandwidth product of 120MHz, while consuming only 6.5mA/per amplifier of supply current. It is ideal for video and high speed signal processing applications such as xDSL and pulse amplifiers. With 150mA output current, the LM7372 can be used for video distribution, as a transformer driver or as a laser diode driver. Operation on ±15V power supplies allows for large signal swings and provides greater dynamic range and signal-tonoise ratio. The LM7372 offers high SFDR and low THD, ideal for ADC/DAC systems
- Тип ОУ: High Speed
- Количество усилителей: 2
- Полоса частот: 120 МГц
- Скорость нарастания: 3000 В/мкс
- Диапазон напряжения питания: 9 В ... 36 В
- Тип корпуса: SOIC
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 7372
- Добротность: 220 МГц
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
