Datasheet LMC6572BIM - National Semiconductor Даташит ИС, операционный усилитель, сдвоенный, 8SOIC — Даташит
National Semiconductor LMC6572BIM
Наименование модели: LMC6572BIM
29 предложений от 20 поставщиков
Микросхема Буферный усилитель, Dual Low Voltage (2.7V to 3V) Operational Amplifier 8-SOIC -40℃ to 85℃
LMC6572BIM
22 ₽
LMC6572BIM
85 ₽
LMC6572BIM
IC Home
LMC6572BIM/NOPB
Описание: ИС, операционный усилитель, сдвоенный, 8SOIC
data sheetСкачать Data Sheet
LMC6572/LMC6574 Dual and Quad Low Voltage (2.7V and 3V) Operational Amplifier
August 2000
General Description
Low voltage operation and low power dissipation make the LMC6574/2 ideal for battery-powered systems.
3V amplifier performance is backed by 2.7V guarantees to ensure operation throughout battery lifetime. These guarantees also enable analog circuits to operate from the same 3.3V supply used for digital logic. Battery life is maximized because each amplifier dissipates only micro-watts of power. The LMC6574/2 does not sacrifice functionality for low voltage operation. The LMC6574/2 generates 120 dB of openloop gain just like a conventional amplifier, but the LMC6574/2 can do this from a 2.7V supply. These amplifiers are designed with features that optimize low voltage operation. The output voltage swings rail-to-rail to maximize signal-to-noise ratio and dynamic signal range. The common-mode input vo
  • Тип ОУ: Low Voltage
  • Количество усилителей: 2
  • Полоса частот: 220 кГц
  • Скорость нарастания: 0.09 В/мкс
  • Диапазон напряжения питания: 2.7 В ... 11 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet LMC6572BIM - National Semiconductor IC, OP AMP, DUAL, 8SOIC
