Datasheet LMC8101MM/NOPB - National Semiconductor Даташит Operational усилитель (Op-Amp) ИС — Даташит
National Semiconductor LMC8101MM/NOPB
Наименование модели: LMC8101MM/NOPB
18 предложений от 12 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC8101MM/NOPB Operational Amplifier, Single, 1 Amplifier, 1MHz, 1V/µs, 2.7V to 10V, MSOP, 8Pins
LMC8101MM/NOPB
49 ₽
Эиком
LMC8101MM/NOPB
от 234 ₽
LMC8101MM/NOPB
LMC8101MM/NOPB
Описание: Operational усилитель (Op-Amp) ИС
data sheetСкачать Data Sheet
LMC8101 Rail-to-Rail Input and Output, 2.7V Op Amp in micro SMD package with Shutdown
May 2004
General Description
The LMC8101 is a Rail-to-Rail Input and Output high performance CMOS operational amplifier.
The LMC8101 is ideal for low voltage (2.7V to 10V) applications requiring Rail-toRail inputs and output. The LMC8101 is supplied in the die sized micro SMD as well as the 8 pin MSOP packages. The micro SMD package requires 75% less board space as compared to the SOT23-5 package. The LMC8101 is an upgrade to the industry standard LMC7101. The LMC8101 incorporates a simple user controlled methodology for shutdown. This allows ease of use while reducing the total supply current to 1nA typical. This extends battery life where power saving is mandated. The shutdown input threshold can be set relative to either V+ or V- using the SL pin (see Application Note section for details). Other enhancements inc
На английском языке: Datasheet LMC8101MM/NOPB - National Semiconductor Operational Amplifier (Op-Amp) IC
