Datasheet LMH6639MA - National Semiconductor Даташит Усилитель, RRO, 190 МГц, POWERWISE, SOIC8 — Даташит
Наименование модели: LMH6639MA
![]() 33 предложений от 18 поставщиков TEXAS INSTRUMENTS LMH6639MA/NOPB Operational Amplifier, Single, 1 Amplifier, 190MHz, 172V/µs, 3V to 12V, SOIC, 8Pins | |||
LMH6639MA/NOPB Texas Instruments | от 112 ₽ | ||
LMH6639MA Texas Instruments | от 201 ₽ | ||
LMH6639MA/NOPB Texas Instruments | от 213 ₽ | ||
LMH6639MA Texas Instruments | по запросу |
Описание: Усилитель, RRO, 190 МГц, POWERWISE, SOIC8
LMH6639 190MHz Rail-to-Rail Output Amplifier with Disable
October 4, 2010
General Description
The LMH6639 is a voltage feedback operational amplifier with a rail-to-rail output drive capability of 110mA.
Employing National's patented VIP10 process, the LMH6639 delivers a bandwidth of 190MHz at a current consumption of only 3.6mA. An input common mode voltage range extending to 0.2V below the V- and to within 1V of V+, makes the LMH6639 a true single supply op-amp. The output voltage range extends to within 30mV of either supply rail providing the user with a dynamic range that is especially desirable in low voltage applications. The LMH6639 offers a slew rate of 172V/s resulting in a full power bandwidth of approximately 28MHz. The LMH6639 also offers protection for the input transistors by using two antiparallel diodes and a series resistor connected across the inputs. The TON value of 83nsec combined with a settling time of
- Тип ОУ: Rail ... Rail
- Количество усилителей: 1
- Полоса частот: 90 МГц
- Скорость нарастания: 200 В/мкс
- Диапазон напряжения питания: 3 В ... 12 В
- Тип корпуса: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 6639
- Добротность: 190 МГц
- Вход / выход: Rail-Rail Outputs
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
Дополнительные аксессуары:
- Linear Technology - LT6200CS8#PBF
- Linear Technology - LT6200CS8-10#PBF
