Datasheet LM392M/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.1 В/мкс, SOIC-8 — Даташит
National Semiconductor LM392M/NOPB
Наименование модели: LM392M/NOPB
35 предложений от 16 поставщиков
IC: операционный усилитель; 1МГц; Ch: 2; SO8; ±1,5÷16ВDC,3÷32ВDC
LM392M/NOPB
от 115 ₽
ЗУМ-СМД
LM392MNOPB
LM392M/NOPB
SUV System
LM392M/NOPB
Описание: ИС, операционный усилитель, 1 МГц, 0.1 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LM392 Low Power Operational Amplifier/Voltage Comparator
August 2000
General Description
The LM392 series consists of 2 independent building block circuits.
One is a high gain, internally frequency compensated operational amplifier, and the other is a precision voltage comparator. Both the operational amplifier and the voltage comparator have been specifically designed to operate from a single power supply over a wide range of voltages. Both circuits have input stages which will commonmode input down to ground when operating from a single power supply. Operation from split power supplies is also possible and the low power supply current is independent of the magnitude of the supply voltage. Application areas include transducer amplifier with pulse shaper, DC gain block with level detector, VCO, as well as all conventional operational amplifier or voltage comparator circuits. Both circuits can be operated directly from the stand
  • Тип ОУ: Low Power
  • Количество усилителей: 2
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.1 В/мкс
  • Диапазон напряжения питания: ± 1.5 В ... ± 16 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LM392M/NOPB - National Semiconductor IC, OP-AMP, 1 MHz, 0.1 V/µs, SOIC-8
