Datasheet LM392N/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.1 В/мкс, DIP-8 — Даташит
National Semiconductor LM392N/NOPB
Наименование модели: LM392N/NOPB
41 предложений от 21 поставщиков
Микросхема Компаратор, TEXAS INSTRUMENTS LM392N/NOPB Operational Amplifier, Single, 1 Amplifier, 1MHz, 0.1V/µs, ± 1.5V to ± 16V, DIP, 8Pins
Контест
LM392N/NOPB
192 ₽
LM392N/NOPB
от 223 ₽
LM392N/NOPB
382 ₽
LM392NNOPB
Описание: ИС, операционный усилитель, 1 МГц, 0.1 В/мкс, DIP-8
data sheetСкачать Data Sheet
LM392 Low Power Operational Amplifier/Voltage Comparator
August 2000
General Description
The LM392 series consists of 2 independent building block circuits.
One is a high gain, internally frequency compensated operational amplifier, and the other is a precision voltage comparator. Both the operational amplifier and the voltage comparator have been specifically designed to operate from a single power supply over a wide range of voltages. Both circuits have input stages which will commonmode input down to ground when operating from a single power supply. Operation from split power supplies is also possible and the low power supply current is independent of the magnitude of the supply voltage. Application areas include transducer amplifier with pulse shaper, DC gain block with level detector, VCO, as well as all conventional operational amplifier or voltage comparator circuits. Both circuits can be operated directly from the stand
  • Тип ОУ: Low Power
  • Количество усилителей: 1
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.1 В/мкс
  • Диапазон напряжения питания: ± 1.5 В ... ± 16 В
  • Тип корпуса: DIP
  • Количество выводов: 8
  • Рабочий диапазон температрур: 0°C ... +70°C
На английском языке: Datasheet LM392N/NOPB - National Semiconductor IC, OP-AMP, 1 MHz, 0.1 V/µs, DIP-8
