Datasheet LM6211MF/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 17 МГц, 5.5 В/мкс, SOT-23-5 — Даташит
Наименование модели: LM6211MF/NOPB
![]() 42 предложений от 17 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LM6211MF/NOPB Texas Instruments | 249 ₽ | ||
LM6211MF/NOPB Texas Instruments | от 739 ₽ | ||
LM6211MF/NOPB | по запросу | ||
LM6211MF/NOPB Texas Instruments | по запросу |
Описание: ИС, операционный усилитель, 17 МГц, 5.5 В/мкс, SOT-23-5
LM6211 Low Noise, RRO Op-Amp with CMOS Input and 24V Operation
June 2006
LM6211 Low Noise, RRO Operational Amplifier with CMOS Input and 24V Operation
General Description
The LM6211 is a wide bandwidth, low noise op amp with a wide supply voltage range and a low input bias current.
The LM6211 operates with a single supply voltage of 5V to 24V, is unity gain stable, has a ground-sensing CMOS input stage, and offers rail-to-rail output swing. The LM6211 is designed to provide optimal performance in high voltage, low noise systems. The LM6211 has a unity gain bandwidth of 20 MHz and an input referred voltage at 10 kHz. The LM6211 noise density of 5.5 nV/ achieves these specifications with a low supply current of only 1 mA. The LM6211 has a low input bias current of 2.3 pA, an output short circuit current of 25 mA and a slew rate of 5.6 V/us. The LM6211 also features a low commonmode input capacitance of 5.5 pF which makes it ideal for use in wide bandwidth and high gain circuits. The LM
- Тип ОУ: Low Noise
- Количество усилителей: 1
- Полоса частот: 17 МГц
- Скорость нарастания: 5.5 В/мкс
- Диапазон напряжения питания: 5 В ... 24 В
- Тип корпуса: SOT-23
- Количество выводов: 5
