Datasheet LM7332MA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 21 МГц, 15.2 В/мкс, SOIC-8 — Даташит
Наименование модели: LM7332MA/NOPB
![]() 29 предложений от 16 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM7332MA/NOPB Operational Amplifier, Dual, 2 Amplifier, 21MHz, 15.2V/µs, 2.5V to 32V, SOIC, 8Pins | |||
LM7332MA/NOPB Texas Instruments | 83 ₽ | ||
LM7332MA/NOPB Texas Instruments | 280 ₽ | ||
LM7332MA/NOPB Texas Instruments | от 658 ₽ | ||
LM7332MA/NOPB | по запросу |
Описание: ИС, операционный усилитель, 21 МГц, 15.2 В/мкс, SOIC-8
LM7332 Dual Rail-to-Rail Input/Output, 30V, Wide Voltage, Range High Output Operational Amplifier
April 16, 2008
LM7332 Dual Rail-to-Rail Input/Output 30V, Wide Voltage Range, High Output Operational Amplifier
General Description
The LM7332 is a dual rail-to-rail input and output amplifier with a wide operating temperature range (-40°C to +125°C) which meets the needs of automotive, industrial and power supply applications.
The LM7332 has the output current of 100 mA which is higher than that of most monolithic op amps. Circuit designs with high output current requirements often need to use discrete transistors because many op amps have low current output. The LM7332 has enough current output to drive many loads directly, saving the cost and space of the discrete transistors. The exceptionally wide operating supply voltage range of 2.5V to 32V alleviates any concerns over functionality under extreme conditions and offers flexibility of use in a multitude of applications. Most of this
- Тип ОУ: Power
- Количество усилителей: 2
- Полоса частот: 21 МГц
- Скорость нарастания: 15.2 В/мкс
- Диапазон напряжения питания: 2.5 В ... 32 В
- Тип корпуса: SOIC
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +125°C
