Datasheet LM8262MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 21 МГц, 12 В/мкс, SOIC-8 — Даташит
National Semiconductor LM8262MM/NOPB
Наименование модели: LM8262MM/NOPB
38 предложений от 20 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM8262MM/NOPB Operational Amplifier, Dual, 2 Amplifier, 21MHz, 15V/µs, 2.5V to 22V, SOIC, 8Pins
LM8262MM/NOPB
351 ₽
LM8262MM/NOPB
LM8262MM/NOPB
LM8262MM/NOPB
Описание: ИС, операционный усилитель, 21 МГц, 12 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LM8262 Dual RRIO, High Output Current & Unlimited Cap Load Op Amp in MSOP
June 2002
General Description
The LM8262 is a Rail-to-Rail input and output Op Amp which can operate with a wide supply voltage range.
This device has high output current drive, greater than Rail-to-Rail input common mode voltage range, unlimited capacitive load drive capability, and provides tested and guaranteed high speed and slew rate. It is specifically designed to handle the requirements of flat panel TFT panel VCOM driver applications as well as being suitable for other low power, and medium speed applications which require ease of use and enhanced performance over existing devices. Greater than Rail-to-Rail input common mode voltage range with 50dB of Common Mode Rejection, allows high side and low side sensing, among many applications, without having any concerns over exceeding the range and no compromise in accuracy. In addition
  • Тип ОУ: High Current
  • Количество усилителей: 2
  • Полоса частот: 21 МГц
  • Скорость нарастания: 12 В/мкс
  • Диапазон напряжения питания: 2.5 В ... 22 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LM8262MM/NOPB - National Semiconductor IC, OP-AMP, 21 MHz, 12 V/µs, SOIC-8
