Datasheet LMC6032IN/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, DIP-8 — Даташит
Наименование модели: LMC6032IN/NOPB
![]() 33 предложений от 16 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6032IN/NOPB Operational Amplifier, Dual, 2 Amplifier, 1.4MHz, 1.1V/µs, 4.75V to 15.5V, DIP, 8Pins | |||
LMC6032IN/NOPB Texas Instruments | 32 ₽ | ||
LMC6032IN/NOPB National Semiconductor | 58 ₽ | ||
LMC6032IN/NOPB Texas Instruments | 60 ₽ | ||
LMC6032IN/NOPB Texas Instruments | от 502 ₽ |
Описание: ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, DIP-8
LMC6032 CMOS Dual Operational Amplifier
August 2000
General Description
The LMC6032 is a CMOS dual operational amplifier which can operate from either a single supply or dual supplies.
Its performance features include an input common-mode range that reaches ground, low input bias current, and high voltage gain into realistic loads, such as 2 k and 600. This chip is built with National's advanced Double-Poly Silicon-Gate CMOS process. See the LMC6034 datasheet for a CMOS quad operational amplifier with these same features. For higher performance characteristics refer to the LMC662. n n n n n n n n Low offset voltage drift: 2.3 µV/°C Ultra low input bias current: 40 fA Input common-mode range includes V- Operating range from +5V to +15V supply ISS = 400 µA/amplifier; independent of V+ Low distortion: 0.01% at 10 kHz Slew rate: 1.1 V/µs Improved performance over TLC272
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 1.4 МГц
- Скорость нарастания: 1.1 В/мкс
- Диапазон напряжения питания: 5 В ... 15 В
- Тип корпуса: DIP
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +105°C
