Datasheet LMC6042AIM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 100 кГц, 0.02 В/мкс, SOIC-8 — Даташит
National Semiconductor LMC6042AIM/NOPB
Наименование модели: LMC6042AIM/NOPB
33 предложений от 16 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6042AIM/NOPB Operational Amplifier, Dual, 2 Amplifier, 100kHz, 0.02V/µs, 4.5V to 15.5V, SOIC, 8Pins
727GS
LMC6042AIM/NOPB
от 147 ₽
LMC6042AIM/NOPB
352 ₽
LMC6042AIM/NOPB
от 442 ₽
LMC6042AIM/NOPB
Описание: ИС, операционный усилитель, 100 кГц, 0.02 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LMC6042 CMOS Dual Micropower Operational Amplifier
August 2000
General Description
Ultra-low power consumption and low input-leakage current are the hallmarks of the LMC6042.
Providing input currents of only 2 fA typical, the LMC6042 can operate from a single supply, has output swing extending to each supply rail, and an input voltage range that includes ground. The LMC6042 is ideal for use in systems requiring ultra-low power consumption. In addition, the insensitivity to latch-up, high output drive, and output swing to ground without requiring external pull-down resistors make it ideal for singlesupply battery-powered systems. Other applications for the LMC6042 include bar code reader amplifiers, magnetic and electric field detectors, and handheld electrometers. This device is built with National's advanced Double-Poly Silicon-Gate CMOS process. See the LMC6041 for a single, and the LMC6044 for a quad amplifier with these features.
  • Тип ОУ: CMOS
  • Количество усилителей: 2
  • Полоса частот: 100 кГц
  • Скорость нарастания: 0.02 В/мкс
  • Диапазон напряжения питания: 4.5 В ... 15.5 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LMC6042AIM/NOPB - National Semiconductor IC, OP-AMP, 100 kHz, 0.02 V/µs, SOIC-8
