Линейка продуктов KEEN SIDE
Datasheet LMC6062IN/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 100 кГц, 0.035 В/мкс, DIP-8 — Даташит
National Semiconductor LMC6062IN/NOPB
Наименование модели: LMC6062IN/NOPB
38 предложений от 18 поставщиков
LMC6062IN/NOPB
от 217 ₽
727GS
LMC6062IN/NOPB
от 327 ₽
LMC6062IN/NOPB
МосЧип
LMC6062IN/NOPB
Описание: ИС, операционный усилитель, 100 кГц, 0.035 В/мкс, DIP-8
data sheetСкачать Data Sheet
LMC6062 Precision CMOS Dual Micropower Operational Amplifier
February 2001
General Description
The LMC6062 is a precision dual low offset voltage, micropower operational amplifier, capable of precision single supply operation.
Performance characteristics include ultra low input bias current, high voltage gain, rail-to-rail output swing, and an input common mode voltage range that includes ground. These features, plus its low power consumption, make the LMC6062 ideally suited for battery powered applications. Other applications using the LMC6062 include precision full-wave rectifiers, integrators, references, sample-and-hold circuits, and true instrumentation amplifiers. This device is built with National's advanced double-Poly Silicon-Gate CMOS process. For designs that require higher speed, see the LMC6082 precision dual operational amplifier. PATENT PENDING
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 100 кГц
  • Скорость нарастания: 0.035 В/мкс
  • Диапазон напряжения питания: 4.5 В ... 15.5 В
  • Тип корпуса: DIP
  • Количество выводов: 8
На английском языке: Datasheet LMC6062IN/NOPB - National Semiconductor IC, OP-AMP, 100 kHz, 0.035 V/µs, DIP-8
