Datasheet LMC6081AIM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.3 МГц, 1.5 В/мкс, SOIC-8 — Даташит
National Semiconductor LMC6081AIM/NOPB
Наименование модели: LMC6081AIM/NOPB
36 предложений от 16 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6081AIM/NOPB Operational Amplifier, Single, 1.3MHz, 1 Amplifier, 1.5V/µs, 4.5V to 15V, SOIC, 8Pins
LMC6081AIM/NOPB
153 ₽
LMC6081AIM/NOPB
от 219 ₽
LMC6081AIM/NOPB
496 ₽
LMC6081AIM/NOPB
Описание: ИС, операционный усилитель, 1.3 МГц, 1.5 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LMC6081 Precision CMOS Single Operational Amplifier
August 2000
General Description
The LMC6081 is a precision low offset voltage operational amplifier, capable of single supply operation.
Performance characteristics include ultra low input bias current, high voltage gain, rail-to-rail output swing, and an input common mode voltage range that includes ground. These features, plus its low offset voltage, make the LMC6081 ideally suited for precision circuit applications. Other applications using the LMC6081 include precision fullwave rectifiers, integrators, references, and sample-andhold circuits. This device is built with National's advanced Double-Poly Silicon-Gate CMOS process. For designs with more critical power demands, see the LMC6061 precision micropower operational amplifier. For a dual or quad operational amplifier with similar features, see the LMC6082 or LMC6084 respectively. PATENT PENDING
  • Тип ОУ: Precision
  • Количество усилителей: 1
  • Полоса частот: 1.3 МГц
  • Скорость нарастания: 1.5 В/мкс
  • Диапазон напряжения питания: 4.5 В ... 15 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LMC6081AIM/NOPB - National Semiconductor IC, OP-AMP, 1.3 MHz, 1.5 V/µs, SOIC-8
