Datasheet LMC6482IMX/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.5 МГц, 1.3 В/мкс, SOIC-8 — Даташит
National Semiconductor LMC6482IMX/NOPB
Наименование модели: LMC6482IMX/NOPB
52 предложений от 22 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6482IMX/NOPB Operational Amplifier, Dual, 2 Amplifier, 1.5MHz, 1.3V/µs, 3V to 15.5V, SOIC, 8Pins
LMC6482IMX/NOPB
25 ₽
Эиком
LMC6482IMX/NOPB
от 140 ₽
LMC6482IMX/NOPB
от 141 ₽
LMC6482IMX@NOPB
Описание: ИС, операционный усилитель, 1.5 МГц, 1.3 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LMC6482 CMOS Dual Rail-To-Rail Input and Output Operational Amplifier
September 2003
General Description
The LMC6482 provides a common-mode range that extends to both supply rails.
This rail-to-rail performance combined with excellent accuracy, due to a high CMRR, makes it unique among rail-to-rail input amplifiers. It is ideal for systems, such as data acquisition, that require a large input signal range. The LMC6482 is also an excellent upgrade for circuits using limited common-mode range amplifiers such as the TLC272 and TLC277. Maximum dynamic signal range is assured in low voltage and single supply systems by the LMC6482's rail-to-rail output swing. The LMC6482's rail-to-rail output swing is guaranteed for loads down to 600. Guaranteed low voltage characteristics and low power dissipation make the LMC6482 especially well-suited for battery-operated systems. LMC6482 is also available in MSOP package which is al
  • Тип ОУ: CMOS
  • Количество усилителей: 2
  • Полоса частот: 1.5 МГц
  • Скорость нарастания: 1.3 В/мкс
  • Диапазон напряжения питания: 3 В ... 15.5 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet LMC6482IMX/NOPB - National Semiconductor IC, OP-AMP, 1.5 MHz, 1.3 V/µs, SOIC-8
