Datasheet LMC6484AIMX/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.5 МГц, 1.3 В/мкс, SOIC-14 — Даташит
National Semiconductor LMC6484AIMX/NOPB
Наименование модели: LMC6484AIMX/NOPB
44 предложений от 22 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6484AIMX/NOPB Operational Amplifier, Dual, 2 Amplifier, 1.5MHz, 1.3V/µs, 3V to 15V, SOIC, 14Pins
LMC6484AIMX/NOPB
от 38 ₽
Microfind
LMC6484AIMXNOPB
101 ₽
Рутоника
LMC6484AIMX/NOPB
107 ₽
Эиком
LMC6484AIMX/NOPB
от 359 ₽
Описание: ИС, операционный усилитель, 1.5 МГц, 1.3 В/мкс, SOIC-14
data sheetСкачать Data Sheet
LMC6484 CMOS Quad Rail-to-Rail Input and Output Operational Amplifier
August 2000
General Description
The LMC6484 provides a common-mode range that extends to both supply rails.
This rail-to-rail performance combined with excellent accuracy, due to a high CMRR, makes it unique among rail-to-rail input amplifiers. It is ideal for systems, such as data acquisition, that require a large input signal range. The LMC6484 is also an excellent upgrade for circuits using limited common-mode range amplifiers such as the TLC274 and TLC279. Maximum dynamic signal range is assured in low voltage and single supply systems by the LMC6484's rail-to-rail output swing. The LMC6484's rail-to-rail output swing is guaranteed for loads down to 600. Guaranteed low voltage characteristics and low power dissipation make the LMC6484 especially well-suited for battery-operated systems. See the LMC6482 data sheet for a Dual CMOS operational a
  • Тип ОУ: CMOS
  • Количество усилителей: 2
  • Полоса частот: 1.5 МГц
  • Скорость нарастания: 1.3 В/мкс
  • Диапазон напряжения питания: 3 В ... 15 В
  • Тип корпуса: SOIC
  • Количество выводов: 14
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet LMC6484AIMX/NOPB - National Semiconductor IC, OP-AMP, 1.5 MHz, 1.3 V/µs, SOIC-14
