Datasheet LMC662CM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, SOIC-8 — Даташит
Наименование модели: LMC662CM/NOPB
![]() 47 предложений от 19 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC662CM/NOPB Operational Amplifier, Dual, 2 Amplifier, 1.4MHz, 1.1V/µs, 4.75V to 15.5V, SOIC, 8Pins | |||
LMC662CM/NOPB Texas Instruments | от 24 ₽ | ||
LMC662CM/NOPB Texas Instruments | 228 ₽ | ||
LMC662CM/NOPB Texas Instruments | от 228 ₽ | ||
LMC662CM/NOPB Texas Instruments | по запросу |
Описание: ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, SOIC-8
LMC662 CMOS Dual Operational Amplifier
April 2003
General Description
The LMC662 CMOS Dual operational amplifier is ideal for operation from a single supply.
It operates from +5V to +15V and features rail-to-rail output swing in addition to an input common-mode range that includes ground. Performance limitations that have plagued CMOS amplifiers in the past are not a problem with this design. Input VOS, drift, and broadband noise as well as voltage gain into realistic loads (2 k and 600) are all equal to or better than widely accepted bipolar equivalents. This chip is built with National's advanced Double-Poly Silicon-Gate CMOS process. See the LMC660 datasheet for a Quad CMOS operational amplifier with these same features.
- Тип ОУ: High Gain
- Количество усилителей: 2
- Полоса частот: 1.4 МГц
- Скорость нарастания: 1.1 В/мкс
- Диапазон напряжения питания: 4.75 В ... 15.5 В
- Тип корпуса: SOIC
- Количество выводов: 8
