Datasheet LMH6622MA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 160 МГц, 85 В/мкс, SOIC-8 — Даташит
Наименование модели: LMH6622MA/NOPB
![]() 39 предложений от 17 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6622MA/NOPB Operational Amplifier, Dual, 2 Amplifier, 160MHz, 85V/µs, ± 2.5V to ± 6V, SOIC, 8Pins | |||
LMH6622MA/NOPB Texas Instruments | от 73 ₽ | ||
LMH6622MA/NOPB Texas Instruments | 356 ₽ | ||
LMH6622MA/NOPB Texas Instruments | от 558 ₽ | ||
LMH6622MA/NOPB Texas Instruments | от 571 ₽ |
Описание: ИС, операционный усилитель, 160 МГц, 85 В/мкс, SOIC-8
LMH6622 Dual Wideband, Low Noise, 160MHz, Operational Amplifiers
July 2005
General Description
The LMH6622 is a dual high speed voltage feedback operational amplifier specifically optimized for low noise.
A voltage , a current noise specifinoise specification of 1.6nV/ , a bandwidth of 160MHz, and a harmonic cation 1.5pA/ distortion specification that exceeds 90dBc combine to make the LMH6622 an ideal choice for the receive channel amplifier in ADSL, VDSL, or other xDSL designs. The LMH6622 operates from ± 2.5V to ± 6V in dual supply mode and from +5V to +12V in single supply configuration. The LMH6622 is stable for AV 2 or AV -1. The fabrication of the LMH6622 on National Semiconductor's advanced VIP10 process enables excellent (160MHz) bandwidth at a current consumption of only 4.3mA/amplifier. Packages for this dual amplifier are the 8-lead SOIC and the 8-lead MSOP.
- Тип ОУ: Wideband
- Количество усилителей: 2
- Полоса частот: 160 МГц
- Скорость нарастания: 85 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 6 В
- Тип корпуса: SOIC
- Количество выводов: 8
