Datasheet LMH6628MA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 300 МГц, 550 В/мкс, SOIC-8 — Даташит
Наименование модели: LMH6628MA/NOPB
![]() 32 предложений от 16 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6628MA/NOPB Operational Amplifier, Dual, 2 Amplifier, 300MHz, 550V/µs, ± 2.5V to ± 6V, SOIC, 8Pins | |||
LMH6628MA/NOPB Texas Instruments | 123 ₽ | ||
LMH6628MA/NOPB National Semiconductor | 234 ₽ | ||
LMH6628MA/NOPB Texas Instruments | от 355 ₽ | ||
LMH6628MA/NOPB HALO | по запросу |
Описание: ИС, операционный усилитель, 300 МГц, 550 В/мкс, SOIC-8
LMH6628 Dual Wideband, Low Noise, Voltage Feedback Op Amp
May 2005
General Description
The National LMH6628 is a high speed dual op amp that offers a traditional voltage feedback topology featuring unity gain stability and slew enhanced circuitry.
The LMH6628's low noise and very low harmonic distortion combine to form a wide dynamic range op amp that operates from a single (5V to 12V) or dual ( ± 5V) power supply. Each of the LMH6628's closely matched channels provides a 300MHz unity gain bandwidth and low input voltage noise ). Low 2nd/3rd harmonic distortion (-65/ density (2nV/ -74dBc at 10MHz) make the LMH6628 a perfect wide dynamic range amplifier for matched I/Q channels. With its fast and accurate settling (12ns to 0.1%), the LMH6628 is also an excellent choice for wide dynamic range, anti-aliasing filters to buffer the inputs of hi resolution analog-to-digital converters. Combining the LMH6628's two tightly matched amp
- Тип ОУ: Low Noise
- Количество усилителей: 2
- Полоса частот: 300 МГц
- Скорость нарастания: 550 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 6 В
- Тип корпуса: SOIC
- Количество выводов: 8
