Линейка продуктов KEEN SIDE
Datasheet LMH6643MA/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 130 МГц, 135 В/мкс, SOIC-8 — Даташит
National Semiconductor LMH6643MA/NOPB
Наименование модели: LMH6643MA/NOPB
31 предложений от 17 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6643MA/NOPB Operational Amplifier, Single, 1 Amplifier, 130MHz, 135V/µs, 2.7V to 12.8V, SOIC, 8Pins
Зенер
Россия и страны ТС
LMH6643MA/NOPB
от 82 ₽
LMH6643MA/NOPB
от 280 ₽
LMH6643MA/NOPB
LMH6643MA/NOPB
Описание: ИС, операционный усилитель, 130 МГц, 135 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LMH6642/LMH6643/LMH6644 Low Power, 130MHz, 75mA Rail-to-Rail Output Amplifiers
November 9, 2009
General Description
The LMH664X family true single supply voltage feedback amplifiers offer high speed (130MHz), low distortion (-62dBc), and exceptionally high output current (approximately 75mA) at low cost and with reduced power consumption when compared against existing devices with similar performance.
Input common mode voltage range extends to 0.5V below V - and 1V from V+. Output voltage range extends to within 40mV of either supply rail, allowing wide dynamic range especially desirable in low voltage applications. The output stage is capable of approximately 75mA in order to drive heavy loads. Fast output Slew Rate (130V/µs) ensures large peak-to-peak output swings can be maintained even at higher speeds, resulting in exceptional full power bandwidth of 40MHz with a 3V supply. These characteristics, alon
  • Тип ОУ: Voltage Feedback
  • Количество усилителей: 1
  • Полоса частот: 130 МГц
  • Скорость нарастания: 135 В/мкс
  • Диапазон напряжения питания: 2.7 В ... 12.8 В
  • Тип корпуса: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LMH6643MA/NOPB - National Semiconductor IC, OP-AMP, 130 MHz, 135 V/µs, SOIC-8
