Datasheet LMH6643MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 130 МГц, 135 В/мкс, MSOP-8 — Даташит
Наименование модели: LMH6643MM/NOPB
Купить LMH6643MM/NOPB на РадиоЛоцман.Цены — от 33 до 381 ₽31 предложений от 19 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6643MM/NOPB Operational Amplifier, Dual, 2 Amplifier, 130MHz, 135V/µs, 2.7V to 12.8V, MSOP, 8Pins | |||
| LMH6643MM/NOPB Texas Instruments | 60 ₽ | ||
| LMH6643MM/NOPB Texas Instruments | по запросу | ||
| LMH6643MM/NOPB | по запросу | ||
Описание: ИС, операционный усилитель, 130 МГц, 135 В/мкс, MSOP-8
LMH6642/LMH6643/LMH6644 Low Power, 130MHz, 75mA Rail-to-Rail Output Amplifiers
November 9, 2009
General Description
The LMH664X family true single supply voltage feedback amplifiers offer high speed (130MHz), low distortion (-62dBc), and exceptionally high output current (approximately 75mA) at low cost and with reduced power consumption when compared against existing devices with similar performance.
Input common mode voltage range extends to 0.5V below V - and 1V from V+. Output voltage range extends to within 40mV of either supply rail, allowing wide dynamic range especially desirable in low voltage applications. The output stage is capable of approximately 75mA in order to drive heavy loads. Fast output Slew Rate (130V/µs) ensures large peak-to-peak output swings can be maintained even at higher speeds, resulting in exceptional full power bandwidth of 40MHz with a 3V supply. These characteristics, alon
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 130 МГц
- Скорость нарастания: 135 В/мкс
- Диапазон напряжения питания: 2.7 В ... 12.8 В
- Тип корпуса: MSOP
- Количество выводов: 8
