Datasheet LMH6646MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 55 МГц, 22 В/мкс, MSOP-8 — Даташит
National Semiconductor LMH6646MM/NOPB
Наименование модели: LMH6646MM/NOPB
42 предложений от 19 поставщиков
LMH6646MM/NOPB
от 55 ₽
LMH6646MM/NOPB
от 742 ₽
LMH6646MM/NOPB
LMH6646MM/NOPB
Описание: ИС, операционный усилитель, 55 МГц, 22 В/мкс, MSOP-8
data sheetСкачать Data Sheet
LMH6645/46/47 2.7V, 650µA, 55MHz, Rail-to-Rail Input and Output Amplifiers with Shutdown Option
June 2005
General Description
The LMHTM6645 (single) and LMH6646 (dual), rail-to-rail input and output voltage feedback amplifiers, offer high speed (55MHz), and low voltage operation (2.7V) in addition to micro-power shutdown capability (LMH6647, single).
Input common mode voltage range exceeds either supply by 0.3V, enhancing ease of use in multitude of applications where previously only inferior devices could be used. Output voltage range extends to within 20mV of either supply rails, allowing wide dynamic range especially in low voltage applications. Even with low supply current of 650µA/amplifier, output current capability is kept at a respectable ± 20mA for driving heavier loads. Important device parameters such as BW, Slew Rate and output current are kept relatively independent of the ope
  • Тип ОУ: Voltage Feedback
  • Количество усилителей: 2
  • Полоса частот: 55 МГц
  • Скорость нарастания: 22 В/мкс
  • Диапазон напряжения питания: 2.5 В ... 12 В
  • Тип корпуса: MSOP
  • Количество выводов: 8
На английском языке: Datasheet LMH6646MM/NOPB - National Semiconductor IC, OP-AMP, 55 MHz, 22 V/µs, MSOP-8
