Datasheet LMH6654MF/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 260 МГц, 200 В/мкс, SOT-23-5 — Даташит
Наименование модели: LMH6654MF/NOPB
37 предложений от 17 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6654MF/NOPB Operational Amplifier, Single, 1 Amplifier, 260MHz, 200V/µs, ± 2.5V to ± 6V, SOT-23, 5Pins | |||
| LMH6654MF/NOPB Texas Instruments | 59 ₽ | ||
| LMH6654MF/NOPB Texas Instruments | 238 ₽ | ||
| LMH6654MF/NOPB Texas Instruments | по запросу | ||
| LMH6654MF/NOPB National Semiconductor | по запросу | ||
Описание: ИС, операционный усилитель, 260 МГц, 200 В/мкс, SOT-23-5
LMH6654/55 Single/Dual Low Power, 250 MHz, Low Noise Amplifiers
August 2001
General Description
The LMH6654/55 single and dual high speed, voltage feedback amplifiers are designed to have unity-gain stable operation with a bandwidth of 250MHz.
They operate from ± 2.5V to ± 6V and each channel consumes only 4.5mA. The amplifiers feature very low voltage noise and wide output swing to maximize signal-to-noise ratio. The LMH6654/55 have a true single supply capability with input common mode voltage range extending 150 mV below negative rail and within 1.3V of the positive rail. LMH6654/55 high speed and low power combination make these products an ideal choice for many portable, high speed application where power is at a premium. The LMH6654 is packaged in SOT23-5 and SOIC-8. The LMH6655 is packaged in MSOP-8 and SOIC-8. The LMH6654/55 are built on National's Advance VIP10TM (Vertically Integrated PNP) complementary bipolar
- Тип ОУ: Voltage Feedback
- Количество усилителей: 1
- Полоса частот: 260 МГц
- Скорость нарастания: 200 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 6 В
- Тип корпуса: SOT-23
- Количество выводов: 5
