Datasheet LMH6657MF/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 140 МГц, 700 В/мкс, SOT-23-5 — Даташит
Наименование модели: LMH6657MF/NOPB
44 предложений от 19 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6657MF/NOPB Operational Amplifier, Single, 1 Amplifier, 270MHz, 700V/µs, 3V to 12V, SOT-23, 5Pins | |||
LMH6657MF/NOPB National Semiconductor | 113 ₽ | ||
LMH6657MFNOPB | по запросу | ||
LMH6657MF/NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, 140 МГц, 700 В/мкс, SOT-23-5
LMH6657/LMH6658 270MHz Single Supply, Single & Dual Amplifiers
October 2004
General Description
The LMH6657/6658 are low-cost operational amplifiers that operate from a single supply with input voltage range extending below the V-.
Based on easy to use voltage feedback topology and boasting fast slew rate (700V/µs) and high speed (140MHz GBWP), the LMH6657 (Single) and LMH6658 (dual) can be used in high speed large signal applications. These applications include instrumentation, communication devices, set-top boxes, etc. With a -3dB BW of 100MHz (AV = +2) and DG & DP of 0.03% & 0.10° respectively, the LMH6657/6658 are well suited for video applications. The output stage can typically supply 80mA into the load with a swing of about 1V from either rail. For Industrial applications, the LMH6657/6658 are excellent cost-saving choices. Input referred voltage noise is low and the input voltage can extend below V- to ease amplif
- Тип ОУ: Voltage Feedback
- Количество усилителей: 1
- Полоса частот: 140 МГц
- Скорость нарастания: 700 В/мкс
- Диапазон напряжения питания: 3 В ... 12 В
- Тип корпуса: SOT-23
- Количество выводов: 5
