Линейка продуктов KEEN SIDE
Datasheet LMP7702MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 2.5 МГц, 1.1 В/мкс, MSOP-8 — Даташит
National Semiconductor LMP7702MM/NOPB
Наименование модели: LMP7702MM/NOPB
47 предложений от 19 поставщиков
LMP7702MM/NOPB
166 ₽
LMP7702MM/NOPB
278 ₽
LMP7702MM/NOPB
от 475 ₽
LMP7702MM/NOPB
Описание: ИС, операционный усилитель, 2.5 МГц, 1.1 В/мкс, MSOP-8
data sheetСкачать Data Sheet
LMP7701/LMP7702/LMP7704 Precision, CMOS Input, RRIO, Wide Supply Range Amplifiers
June 23, 2008
General Description
The LMP7701/LMP7702/LMP7704 are single, dual, and quad low offset voltage, rail-to-rail input and output precision amplifiers each with a CMOS input stage and a wide supply voltage range.
The LMP7701/LMP7702/LMP7704 are part of the LMP® precision amplifier family and are ideal for sensor interface and other instrumentation applications. The guaranteed low offset voltage of less than ±200 µV along with the guaranteed low input bias current of less than ±1 pA make the LMP7701 ideal for precision applications. The LMP7701/LMP7702/LMP7704 are built utilizing VIP50 technology, which allows the combination of a CMOS input stage and a 12V common mode and supply voltage range. This makes the LMP7701/LMP7702/LMP7704 great choices in many applications where conventional CMOS parts cannot operate und
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 2.5 МГц
  • Скорость нарастания: 1.1 В/мкс
  • Диапазон напряжения питания: 2.7 В ... 12 В
  • Тип корпуса: MSOP
  • Количество выводов: 8
На английском языке: Datasheet LMP7702MM/NOPB - National Semiconductor IC, OP-AMP, 2.5 MHz, 1.1 V/µs, MSOP-8
