Datasheet LMV712MM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 5 МГц, 5 В/мкс, MSOP-10 — Даташит
National Semiconductor LMV712MM/NOPB
Наименование модели: LMV712MM/NOPB
35 предложений от 15 поставщиков
LMV712MM/NOPB
25 ₽
LMV712MM/NOPB
36 ₽
LMV712MM/NOPB
от 221 ₽
SUV System
LMV712MM/NOPB
Описание: ИС, операционный усилитель, 5 МГц, 5 В/мкс, MSOP-10
data sheetСкачать Data Sheet
LMV712 Low Power, Low Noise, High Output, RRIO Dual Operational Amplifier with Independent Shutdown
March 5, 2010
General Description
The LMV712 duals are high performance BiCMOS operational amplifiers intended for applications requiring Rail-toRail inputs combined with speed and low noise.
They offer a bandwidth of 5MHz and a slew rate of 5 V/µs and can handle capacitive loads of up to 200pF without oscillation. The LMV712 is guaranteed to operate from 2.7V to 5.5V and offers two independent shutdown pins. This feature allows disabling of each device separately and reduces the supply current to less than 1µA typical. The output voltage rapidly ramps up smoothly with no glitch as the amplifier comes out of the shutdown mode. The LMV712 with the shutdown feature is offered in space saving 10-Bump micro SMD and 10-Pin Leadless Leadframe Package (LLP) packages. It is also offered in 10-Pi
  • Тип ОУ: Low Power
  • Количество усилителей: 1
  • Полоса частот: 5 МГц
  • Скорость нарастания: 5 В/мкс
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • Тип корпуса: MSOP
  • Количество выводов: 10
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet LMV712MM/NOPB - National Semiconductor IC, OP-AMP, 5 MHz, 5 V/µs, MSOP-10
