Datasheet LMV721M7/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 10 МГц, 5.25 В/мкс, SC-70-5 — Даташит
Наименование модели: LMV721M7/NOPB
38 предложений от 18 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMV721M7/NOPB Operational Amplifier, Single, 1 Amplifier, 10MHz, 5.25V/µs, 2.2V to 5.5V, SC-70, 5Pins | |||
| LMV721M7/NOPB Texas Instruments | 100 ₽ | ||
| LMV721M7/NOPB Texas Instruments | 129 ₽ | ||
| LMV721M7/NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, 10 МГц, 5.25 В/мкс, SC-70-5
LMV721/LMV722 10MHz, Low Noise, Low Voltage, and Low Power Operational Amplifier
July 2, 2008
General Description
The LMV721 (Single) and LMV722 (Dual) are low noise, low voltage, and low power op amps, that can be designed into a wide range of applications.
The LMV721/LMV722 has a unity gain bandwidth of 10MHz, a slew rate of 5V/us, and a quiescent current of 930uA/amplifier at 2.2V. The LMV721/722 are designed to provide optimal performance in low voltage and low noise systems. They provide rail-to-rail output swing into heavy loads. The input commonmode voltage range includes ground, and the maximum input offset voltage are 3.5mV (Over Temp.) for the LMV721/ LMV722. Their capacitive load capability is also good at low supply voltages. The operating range is from 2.2V to 5.5V. The chip is built with National's advanced Submicron SiliconGate BiCMOS process. The single version, LMV721, is available in 5
- Тип ОУ: Low Noise
- Количество усилителей: 1
- Полоса частот: 10 МГц
- Скорость нарастания: 5.25 В/мкс
- Диапазон напряжения питания: 2.2 В ... 5.5 В
- Тип корпуса: SC-70
- Количество выводов: 5
