Datasheet LMV793MF/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 88 МГц, 35 В/мкс, SOT-23-5 — Даташит
National Semiconductor LMV793MF/NOPB
Наименование модели: LMV793MF/NOPB
Описание: ИС, операционный усилитель, 88 МГц, 35 В/мкс, SOT-23-5
data sheetСкачать Data Sheet
LMV793/LMV794 88 MHz, Low Noise, 1.8V CMOS Input, Decompensated Operational Amplifiers
June 23, 2008
General Description
The LMV793 (single) and the LMV794 (dual) CMOS input operational amplifiers offer a low input voltage noise density while consuming only 1.15 mA (LMV793) of of 5.8 nV/ quiescent current.
The LMV793/LMV794 are stable at a gain of 10 and have a gain bandwidth product (GBW) of 88 MHz. The LMV793/LMV794 have a supply voltage range of 1.8V to 5.5V and can operate from a single supply. The LMV793/ LMV794 each feature a rail-to-rail output stage capable of driving a 600 load and sourcing as much as 60 mA of current. The LMV793/LMV794 provide optimal performance in low voltage and low noise systems. A CMOS input stage, with typical input bias currents in the range of a few femto-Amperes, and an input common mode voltage range, which includes ground, make the LMV793/LMV794 ideal for low p
  • Тип ОУ: Low Noise
  • Количество усилителей: 1
  • Полоса частот: 88 МГц
  • Скорость нарастания: 35 В/мкс
  • Диапазон напряжения питания: 1.8 В ... 5.5 В
  • Тип корпуса: SOT-23
  • Количество выводов: 5
На английском языке: Datasheet LMV793MF/NOPB - National Semiconductor IC, OP-AMP, 88 MHz, 35 V/µs, SOT-23-5
Политика конфиденциальности
