Datasheet LMV822MX/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 5.6 МГц, 2 В/мкс, SOIC-8 — Даташит
Наименование модели: LMV822MX/NOPB
Купить LMV822MX/NOPB на РадиоЛоцман.Цены — от 19 до 180 ₽34 предложений от 21 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMV822MX/NOPB Operational Amplifier, Dual, 2 Amplifier, 5.6MHz, 2V/µs, 2.5V to 5.5V, SOIC, 8Pins | |||
| LMV822MX/NOPB Texas Instruments | от 19 ₽ | ||
| LMV822MX/NOPB | по запросу | ||
| LMV822MX/NOPB Texas Instruments | по запросу | ||
| LMV822MX@NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, 5.6 МГц, 2 В/мкс, SOIC-8
LMV821 / LMV822 / LMV824 Single/Dual Quad Low Voltage, Low Power, RRO, 5 MHz Op Amps
November 2003
LMV821 Single/ LMV822 Dual/ LMV824 Quad Low Voltage, Low Power, R-to-R Output, 5 MHz Op Amps
General Description
The LMV821/LMV822/LMV824 bring performance and economy to low voltage / low power systems.
With a 5 MHz unity-gain frequency and a guaranteed 1.4 V/µs slew rate, the quiescent current is only 220 µA/amplifier (2.7 V). They provide rail-to-rail (R-to-R) output swing into heavy loads (600 Guarantees). The input common-mode voltage range includes ground, and the maximum input offset voltage is 3.5mV (Guaranteed). They are also capable of comfortably driving large capacitive loads (refer to the application notes section). The LMV821 (single) is available in the ultra tiny SC70-5 package, which is about half the size of the previous title holder, the SOT23-5. Overall, the LMV821/LMV822/LMV824 (Single/Dual/Quad) are low voltage, low power, performance op amps, that can be designed
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 5.6 МГц
- Скорость нарастания: 2 В/мкс
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Тип корпуса: SOIC
- Количество выводов: 8
- Рабочий диапазон температрур: -40°C ... +85°C
