Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet LPV521MGE/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 6.2 кГц, 0.0024 В/мкс, SC-70-5 — Даташит
National Semiconductor LPV521MGE/NOPB
Наименование модели: LPV521MGE/NOPB
Описание: ИС, операционный усилитель, 6.2 кГц, 0.0024 В/мкс, SC-70-5
data sheetСкачать Data Sheet
LPV521 Nanopower, 1.8V, RRIO, CMOS Input, Operational Amplifier
August 24, 2009
General Description
The LPV521 is a single nanopower 552 nW amplifier designed for ultra long life battery applications.
The operating voltage range of 1.6V to 5.5V coupled with typically 351 nA of supply current make it well suited for RFID readers and remote sensor nanopower applications. The device has input common mode voltage 0.1V over the rails, guaranteed TCVOS and voltage swing to the rail output performance. The LPV521 has a carefully designed CMOS input stage that outperforms competitors with typically 40 fA IBIAS currents. This low input current significantly reduces IBIAS and IOS errors introduced in megohm resistance, high impedance photodiode, and charge sense situations. The LPV521 is a member of the PowerWise® family and has an exceptional power-to-performance ratio. The wide input common mode voltage range, guaranteed 1 mV VO
  • Тип ОУ: Low Power
  • Количество усилителей: 1
  • Полоса частот: 6.2 кГц
  • Скорость нарастания: 0.0024 В/мкс
  • Диапазон напряжения питания: 1.6 В ... 5.5 В
  • Тип корпуса: SC-70
  • Количество выводов: 5
Дополнительные аксессуары:
  • National Semiconductor - 551012922-001/NOPB
На английском языке: Datasheet LPV521MGE/NOPB - National Semiconductor IC, OP-AMP, 6.2 kHz, 0.0024 V/µs, SC-70-5
Политика конфиденциальности
