Datasheet LM6588MT/NOPB - National Semiconductor Даташит ИС, операционный усилитель TFT-LCD QD 16 В 14TSSOP — Даташит
Наименование модели: LM6588MT/NOPB
![]() 37 предложений от 15 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM6588MT/NOPB Operational Amplifier, Quad, 4 Amplifier, 15.4MHz, 15V/µs, 5V to 16V, TSSOP, 14Pins | |||
LM6588MT/NOPB Texas Instruments | 118 ₽ | ||
LM6588MT/NOPB Texas Instruments | от 214 ₽ | ||
LM6588MT/NOPB Texas Instruments | 381 ₽ | ||
LM6588MT/NOPB Texas Instruments | 417 ₽ |
Описание: ИС, операционный усилитель TFT-LCD QD 16 В 14TSSOP
LM6588 TFT-LCD Quad, 16V RRIO High Output Current Operational Amplifier
July 2005
General Description
The LM6588 is a low power, high voltage, rail-to-rail inputoutput amplifier ideally suited for LCD panel VCOM driver and gamma buffer applications.
The LM6588 contains four unity gain stable amplifiers in one package. It provides a common mode input ability of 0.5V beyond the supply rails, as well as an output voltage range that extends to within 50mV of either supply rail. With these capabilities, the LM6588 provides maximum dynamic range at any supply voltage. Operating on supplies ranging from 5V to 16V, while consuming only 750µA per amplifier, the LM6588 has a bandwidth of 24MHz (-3dB). The LM6588 also features fast slewing and settling times, along with a high continuous output capability of 75mA. This output stage is capable of delivering approximately 200mA peak currents in order to charge or discharge ca
- Тип ОУ: Low Power
- Количество усилителей: 4
- Полоса частот: 15.4 МГц
- Скорость нарастания: 15 В/мкс
- Диапазон напряжения питания: 5 В ... 16 В
- Тип корпуса: TSSOP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 6588
- Добротность: 24 МГц
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
