Datasheet LM148J - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.5 В/мкс, DIP-14 — Даташит
Наименование модели: LM148J
![]() 48 предложений от 26 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LM148J/PB Texas Instruments | 186 ₽ | ||
LM148J Texas Instruments | по запросу | ||
LM148J Vishay | по запросу | ||
LM148J/PB Texas Instruments | по запросу |
Описание: ИС, операционный усилитель, 1 МГц, 0.5 В/мкс, DIP-14
LM148/LM248/LM348 Series Quad 741 Op Amp
November 2003
LM148/LM248/LM348 Quad 741 Op Amps
General Description
The LM148 series is a true quad 741.
It consists of four independent, high gain, internally compensated, low power operational amplifiers which have been designed to provide functional characteristics identical to those of the familiar 741 operational amplifier. In addition the total supply current for all four amplifiers is comparable to the supply current of a single 741 type op amp. Other features include input offset currents and input bias current which are much less than those of a standard 741. Also, excellent isolation between amplifiers has been achieved by independently biasing each amplifier and using layout techniques which minimize thermal coupling. The LM148 can be used anywhere multiple 741 or 1558 type amplifiers are being used and in applications where amplifier matching or high packing density is required. For lower power refer to LF444.
- Тип ОУ: Low Power
- Количество усилителей: 4
- Полоса частот: 1 МГц
- Скорость нарастания: 0.5 В/мкс
- Диапазон напряжения питания: 10 В ... 44 В
- Тип корпуса: DIP
- Количество выводов: 14
- Рабочий диапазон температрур: -55°C ... +125°C
