Линейка продуктов KEEN SIDE
Datasheet LM2902N/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.5 В/мкс, DIP-14 — Даташит
National Semiconductor LM2902N/NOPB
Наименование модели: LM2902N/NOPB
37 предложений от 14 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM2902N/NOPB Operational Amplifier, Quad, 4 Amplifier, 1MHz, 0.5V/µs, 3V to 26V, DIP, 14Pins
LM2902N/NOPB
от 14 ₽
LM2902N/NOPB
34 ₽
727GS
LM2902N/NOPB
от 43 ₽
LM2902N/NOPB
Описание: ИС, операционный усилитель, 1 МГц, 0.5 В/мкс, DIP-14
data sheetСкачать Data Sheet
LM124/LM224/LM324/LM2902 Low Power Quad Operational Amplifiers
August 2000
General Description
The LM124 series consists of four independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifiers, DC gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM124 series can be directly operated off of the standard +5V power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring the additional ± 15V power supplies.
  • Тип ОУ: Low Power
  • Количество усилителей: 4
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.5 В/мкс
  • Диапазон напряжения питания: 3 В ... 26 В
  • Тип корпуса: DIP
  • Количество выводов: 14
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet LM2902N/NOPB - National Semiconductor IC, OP-AMP, 1 MHz, 0.5 V/µs, DIP-14
