Datasheet LM324AMX/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.5 В/мкс, SOIC-14 — Даташит
National Semiconductor LM324AMX/NOPB
Наименование модели: LM324AMX/NOPB
31 предложений от 22 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM324AMX/NOPB Operational Amplifier, Quad, 4 Amplifier, 1MHz, 0.5V/µs, 3V to 32V, SOIC, 14Pins
LM324AMX/NOPB
43 ₽
LM324AMX/NOPB
45 ₽
Эиком
LM324AMX/NOPB
106 ₽
LM324AMX/NOPB
107 ₽
Описание: ИС, операционный усилитель, 1 МГц, 0.5 В/мкс, SOIC-14
data sheetСкачать Data Sheet
LM124/LM224/LM324/LM2902 Low Power Quad Operational Amplifiers
August 2000
General Description
The LM124 series consists of four independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages.
Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifiers, DC gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM124 series can be directly operated off of the standard +5V power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring the additional ± 15V power supplies.
  • Тип ОУ: Low Power
  • Количество усилителей: 4
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.5 В/мкс
  • Диапазон напряжения питания: 3 В ... 32 В
  • Тип корпуса: SOIC
  • Количество выводов: 14
  • Рабочий диапазон температрур: 0°C ... +70°C
Дополнительные аксессуары:
  • National Semiconductor - LM324AM/NOPB
На английском языке: Datasheet LM324AMX/NOPB - National Semiconductor IC, OP-AMP, 1 MHz, 0.5 V/µs, SOIC-14
