Datasheet LM6134AIM/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 10 МГц, 14 В/мкс, SOIC-14 — Даташит
Наименование модели: LM6134AIM/NOPB
23 предложений от 16 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM6134AIM/NOPB Operational Amplifier, Quad, 10MHz, 4 Amplifier, 14V/µs, 2.7V to 24V, SOIC, 14Pins | |||
LM6134AIM/NOPB Texas Instruments | 73 ₽ | ||
LM6134AIM/NOPB Texas Instruments | 982 ₽ | ||
LM6134AIM/NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, 10 МГц, 14 В/мкс, SOIC-14
LM6132 and LM6134 Dual and Quad, Low Power 10 MHz Rail-to-Rail I/O Operational Amplifiers
November 2004
LM6132/LM6134 Dual and Quad Low Power 10 MHz Rail-to-Rail I/O Operational Amplifiers
General Description
The LM6132/34 provides new levels of speed vs.
power performance in applications where low voltage supplies or power limitations previously made compromise necessary. With only 360 µA/amp supply current, the 10 MHz gainbandwidth of this device supports new portable applications where higher power devices unacceptably drain battery life. The LM6132/34 can be driven by voltages that exceed both power supply rails, thus eliminating concerns over exceeding the common-mode voltage range. The rail-to-rail output swing capability provides the maximum possible dynamic range at the output. This is particularly important when operating on low supply voltages. The LM6132/34 can also drive large capacitive loads without oscillating. Operating on supplies from 2.7V to over 24V, the LM6132/34
- Тип ОУ: Low Power
- Количество усилителей: 4
- Полоса частот: 10 МГц
- Скорость нарастания: 14 В/мкс
- Диапазон напряжения питания: 2.7 В ... 24 В
- Тип корпуса: SOIC
- Количество выводов: 14
