Datasheet LMC6484AIN/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.5 МГц, 1.3 В/мкс, DIP-14 — Даташит
Наименование модели: LMC6484AIN/NOPB
![]() 47 предложений от 19 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6484AIN/NOPB Operational Amplifier, Quad, 4 Amplifier, 1.5MHz, 1.3V/µs, 3V to 15V, DIP, 14Pins | |||
LMC6484AIN/NOPB Texas Instruments | 103 ₽ | ||
LMC6484AIN/NOPB Texas Instruments | от 145 ₽ | ||
LMC6484AIN/NOPB Texas Instruments | по запросу | ||
Описание: ИС, операционный усилитель, 1.5 МГц, 1.3 В/мкс, DIP-14
LMC6484 CMOS Quad Rail-to-Rail Input and Output Operational Amplifier
August 2000
General Description
The LMC6484 provides a common-mode range that extends to both supply rails.
This rail-to-rail performance combined with excellent accuracy, due to a high CMRR, makes it unique among rail-to-rail input amplifiers. It is ideal for systems, such as data acquisition, that require a large input signal range. The LMC6484 is also an excellent upgrade for circuits using limited common-mode range amplifiers such as the TLC274 and TLC279. Maximum dynamic signal range is assured in low voltage and single supply systems by the LMC6484's rail-to-rail output swing. The LMC6484's rail-to-rail output swing is guaranteed for loads down to 600. Guaranteed low voltage characteristics and low power dissipation make the LMC6484 especially well-suited for battery-operated systems. See the LMC6482 data sheet for a Dual CMOS operational a
- Тип ОУ: CMOS
- Количество усилителей: 4
- Полоса частот: 1.5 МГц
- Скорость нарастания: 1.3 В/мкс
- Диапазон напряжения питания: 3 В ... 15 В
- Тип корпуса: DIP
- Количество выводов: 14
- Рабочий диапазон температрур: -40°C ... +85°C
