Datasheet LMC660AIN/NOPB - National Semiconductor Даташит ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, DIP-14 — Даташит
National Semiconductor LMC660AIN/NOPB
Наименование модели: LMC660AIN/NOPB
28 предложений от 16 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC660AIN/NOPB Operational Amplifier, 4 Amplifier, 1.4MHz, 1.1V/µs, 4.75V to 15.5V, DIP, 14Pins
LMC660AIN/NOPB
73 ₽
LMC660AIN/NOPB
254 ₽
LMC660AIN/NOPB
SUV System
LMC660AIN/NOPB
Описание: ИС, операционный усилитель, 1.4 МГц, 1.1 В/мкс, DIP-14
data sheetСкачать Data Sheet
LMC660 CMOS Quad Operational Amplifier
June 2006
General Description
The LMC660 CMOS Quad operational amplifier is ideal for operation from a single supply.
It operates from +5V to +15.5V and features rail-to-rail output swing in addition to an input common-mode range that includes ground. Performance limitations that have plagued CMOS amplifiers in the past are not a problem with this design. Input VOS, drift, and broadband noise as well as voltage gain into realistic loads (2 k and 600) are all equal to or better than widely accepted bipolar equivalents. This chip is built with National's advanced Double-Poly Silicon-Gate CMOS process. See the LMC662 datasheet for a dual CMOS operational amplifier with these same features. n n n n n n n n Low input offset voltage: 3 mV Low offset voltage drift: 1.3 µV/°C Ultra low input bias current: 2 fA Input common-mode range includes V- Operating range from +5V to +15.5V supply ISS = 375 µA/amplifier; inde
  • Тип ОУ: CMOS
  • Количество усилителей: 4
  • Полоса частот: 1.4 МГц
  • Скорость нарастания: 1.1 В/мкс
  • Диапазон напряжения питания: 5 В ... 15.5 В
  • Тип корпуса: DIP
  • Количество выводов: 14
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet LMC660AIN/NOPB - National Semiconductor IC, OP-AMP, 1.4 MHz, 1.1 V/µs, DIP-14
