Datasheet MC3403PG - ON Semiconductor Даташит ИС, операционный усилитель, 1 МГц, 0.6 В/мкс, DIP-14 — Даташит
ON Semiconductor MC3403PG
Наименование модели: MC3403PG
14 предложений от 14 поставщиков
IC OPAMP GP 4 CIRCUIT 14DIP. General Purpose Amplifier 4 Circuit 14-PDIP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
MC3403PG
25 ₽
SUV System
MC3403PG
Рутоника
MC3403PG
MC3403PG
Производитель: ON Semiconductor
Описание: ИС, операционный усилитель, 1 МГц, 0.6 В/мкс, DIP-14
data sheetСкачать Data Sheet
MC3403, MC3303 Single Supply Quad Operational Amplifiers
The MC3403 is a low cost, quad operational amplifier with true differential inputs.
The device has electrical characteristics similar to the popular MC1741C. However, the MC3403 has several distinct advantages over standard operational amplifier types in single supply applications. The quad amplifier can operate at supply voltages as low as 3.0 V or as high as 36 V with quiescent currents about one third of those associated with the MC1741C (on a per amplifier basis). The common mode input range includes the negative supply, thereby eliminating the necessity for external biasing components in many applications. The output voltage range also includes the negative power supply voltage.
Features http://onsemi.com MARKING DIAGRAMS
14 14 1 SOIC-14 D SUFFIX CASE 751A 1 MC3x03DG AWLYWW
  • Тип ОУ: Low Bias Current
  • Количество усилителей: 4
  • Полоса частот: 1 МГц
  • Скорость нарастания: 0.6 В/мкс
  • Диапазон напряжения питания: ± 1.5 В ... ± 18 В
  • Тип корпуса: DIP
  • Количество выводов: 14
На английском языке: Datasheet MC3403PG - ON Semiconductor IC, OP-AMP, 1 MHz, 0.6 V/µs, DIP-14
